Author Topic: Duplicate/clone autoplaylist  (Read 3104 times)
choncie
I have some rather complex auto-playlists defined. Sometimes I want to create a duplicate of one and just modify 1 or 2 parameters. But there doesn't appear to be any way to duplicate or clone an APL. Can that be added at some point? It would save me a lot of busy work.  :P ;D
Thanks...
i will look to implement this at some point in the next MB version, but for now you can just copy the file in windows explorer - the playlists are located in the Playlists sub-folder of your musicbee library. Auto-playlists have a .xautopf extension
choncie
Thanks Steven, that's definitely a liveable workaround for the time being, thanks for the info!  :D
+1
Along with having auto playlists remember what you had typed in if you change the parameter you're using.
Latest patches (3.5/3.6)
