Author Topic: Auto-playlists: filter out duplicates option  (Read 2756 times)
ogdahl
Would it be possible to have the V2 auto-playlist 'filter out duplicates...' option select tracks based on best quality, i.e. lossless before lossy or the track with highest bitrate in case only one kind (lossless or lossy) exists?
i have made a simple change so it chooses lossless over lossy, then m4a, and finally if they are the same format then the highest bitrate.
its in the next update
