Author Topic: Clarity Skin  (Read 23296 times)
Underneath
Clarity is a very music-inspired skin. The concept for color harmonies I've been carrying for two years. Four months ago, a release was planned for MediaMonkey with the title "Clarity Fusion", but I discovered MusicBee, a piece of software that beats everything in this category. Skinning with MediaMonkey was very expensive and limited, so I realize this project now for MusicBee. At first glance I was surprised that "Smooth Tuned Blue" worked with similar colors.
First time released: July 05, 2012
Last update: July 11, 2012
Current version: 1.0.2.80
Download: https://www.dropbox.com/s/vlh89smet06azyc/Clarity.zip
Main Skin
Full size: http://i.imgur.com/5BT8O.png?1
Mini Player
Flat Player
Last Edit: August 08, 2012, 12:53:41 AM by Underneath
beeing good
That's very nice, definitely one for my collection!
Greb
Funny. When I did the 'Smooth Tuned Blue' skins what I was trying to do was exactly a skin that was clear to see. I used a middle point between iTunes and Linux Mint.
BTW, nice skin, but it looks a bit weird when you go out of the configuration you're using. The one I use, for example:
It's like... too black.
EDIT
For example, changing the 0,0,0 colour for 10,15,22 that is a darker and more saturated version of the lateral colour, it changes this way:
to
I think it looks less aggresive.
Last Edit: July 05, 2012, 01:57:09 PM by Greb
Underneath
Version: 1.0.0.20
I fixed a few little issues and changed all 0,0,0's to 10,15,22.
Greb
Version: 1.0.0.20
Well, it was a quick fix that looked better for me. Don't do it just because I said so!!
Anyway, I think this skin can be one of the best ones, with beeTunes (and better than the ones I did, that are a bit outdated right now).
Underneath
I took your suggestion just fine, because I love working with dark colours. The code 10,15,22 or something like that I've used so many times, the proportion of more blue has a quite amazing effect on the result.
Underneath
Hey!
I made major changes in colour harmonies (at first sight you won't see any changes, but there's a lot of final touch). Other changes: Buttons in menus are black, edit pop-up re-designed.
Version: 1.0.1.60
lnminente
It has a nice combination of colours. Thanks for sharing Underneath :)
Underneath
Changes in v1.0.2.70: drop down menu re-designed, little issues fixed, buttons re-designed, colour adjustments.
VX
Thanks for sharing. The best Smooth Tuned variation I've ever seen  :)
beeing good
Thanks Underneath, really love this skin.
lnminente
I think this skin could benefit a lot from the new elements "to override the tabs bar when docked in the caption bar and the player is docked at the top":
  <element id="TabsBar.TabInCaptionBarTop.Default" bg="15,215,215" fg="30,30,130" bdr="170,10,170" />
  <element id="TabsBar.TabInCaptionBarTop.Highlight" bg="145,245,5" fg="220,220,20" bdr="10,10,190" />
A unity aspect with the currently active tab, and darker inactive tabs would be pretty nice
beeing good
I just have to echo my last post...looks fantastic. I love what you've done with the flat player, it looks so very stylish.
