Author Topic: up-to-date master skin xml file on niblseed  (Read 2928 times)
jistme
As others have mentioned/requested in skin topics, it would be useful to have an updated 'master skin' xml file for skinning purposes on niblseed.
If I understand correctly there once was a folder named 'Patches', containing such and an up-to-date skin creator, but that folder is not there anymore.
i'm not sure what is meant by the master skin. I have just uploaded the source xml to the default musicbee skin in your other topic, but its a standard skin
the bitmap skin editor has an example source file, so you could change replace it with the default skin and set the bitmap images as appropriate.
this topic has the information on bitmap skins:
http://getmusicbee.com/forum/index.php?topic=3834.0
jistme
Thnx.
I'm gonna try not to open my mouth about this subject again before I understand it all a little better.
jistme
I lied.
I'm gonna open my mouth again while I think I don't have a complete grasp yet:
If I understand correctly from imminentes posting (http://getmusicbee.com/forum/index.php?topic=6243.msg39075#msg39075), to be able to edit e.g. the position of playing controls, also the image files are needed.
If so, can you give a link to them too, or could maybe an updated SkinCreator do the trick?
