Author Topic: Tag Handling Wish  (Read 4985 times)
Steven...
Would you please consider adding a tag handling preference to ignore prefixes when sorting by track titles and by album titles?  I envision this as similar to what you currently have when sorting artists.
Thanks.
EDIT:
And if you're willing to take that step, please include the ability to ignore punctuation when sorting.  In particular on title tags.  Such as in a track call (I Can't Get No) Satisfaction, or 'Till The Morning Comes.
Thanks again.
Last Edit: January 29, 2010, 10:01:49 PM by phred
i'll look at this for the next update but one thing - could you not just include the punctuation marks you want to exclude in the prefix list? Its just a comma separated list eg.
The, '
Prefix list???
Do you mean the field called "ignore prefixes" in the Tag Preferences window under "tag handling"?
I thought that was invoked only when sorting artists.
it is currently and i will also include title and album. I meant your second request to also ignore punctuation marks. You can just add them to the list already
Ahhh ... nice.
Especially the artist/track part.
Thanks Steven.
Steven...
Using 1.2.3697.24434.
Either I'm doing it wrong, or it isn't working.
In the 'tag handling' section of the tags preferences window, I have "ignore prefixes:" checked and in the field I have entered:
The, (, ',
In the 'custom tags' section I have CUSTOM 1 as Sort Artist /Artist Sort-Order, CUSTOM 2 as Sort Tittle/Title Sort-Order, and CUSTOM 3 as Sort Album/Album-Sort Order.
I have a track with the title tag "(I Can't Get No) Satisfaction"
I have had edited the Title Sort-Order tag to be "I Can't Get No Satisfaction" which kept the track sorted as if the "(" was still there.  I also tagged it with the Title Sort-Order to be "Satisfaction" with the same results.
I use the same procedure for getting rid of the prefix "The" in "The Rolling Stones" and the artist sorts with the Rs and not the Ts.  I figured this is how the Title sort would work.
What am I doing wrong?
Thanks.
i see there is a bug - it actually looks for '( ' and not '(' so i will fix that
And working just fine.
Thanks Steven.
