Got this idea while discussing another issue (of locking tabs) here:
http://getmusicbee.com/forum/index.php?topic=6612.0When you want to open a new tab, the default view that loads in it is "Music" (collection). as my collection is big (ca. 90 000 songs), it takes a few seconds to 'load' it and only then I can pick a playlist I need for that new tab.
1. Wouldn't it be better if the new tab was empty?
As for me, rarely I do open a new tab to go to Music, usually I want to go to more specific direction (playlist, folder). So opening Music on deafault is not only illogical (for me at least), but also takes much more time (especially with big music collections).
Think about it as if it was a web browser (as I believe the tab functionality is derived from browsers):
If you open a new tab in Opera/Firefox/Chrome, would you like it to go to your homepage directly or rather have it empty or with speed dial?
It's the same with MusicBee I guess.
2. writing about this I came up with a further idea - how about having a Speed Dial with most commonly used playlists/folders after opening a new tab? It could be customisable as speed dials in web browsers:
- having shortcuts for mostly used directories based on statistics or option to set directories on your own
- number of speed dial windows (depending on number of diff. directories you use)
- even a cover for each speed dial window (a cover of specific record - especially if the speed dial window is set to go to that record - or any art you want and choose)
