Hi everyone,
I'm using a very modern, fantastic fully digital line up: W7P, MB (Wasapi), Musical Fidelity V-Link 192, S/PDIF, K+H O300D.
It sounds OK, but somewhere I need to adjust the volume control in a decent way, so I was advised to switch to MB.
I came across a few problems to which I hope to find an answer here:
1: the VC in MB is a bit too course and the logarithmic mode doesn't function with Wasapi. It is, what we call in Holland, a matter of "ant-tickling" to adjust it.
2: Making user defined buttons is a fantastic option! But these buttons also are far too course to make it functional for daily use.
3: I try to use a Griffin Powermate (so I have a real and solid "knob") to adjust it. Unfortunately it only sees the Windows mixer volume control and short keys, but...:
4: The necessary short key for volume changes is Alt+Ctrl+UP/DOWN, but these short keys have priority in my motherboard to switch my monitor upside down....
Question: Can I change the volume control parameters to be more detailed?
Question: Can I change the short keys for the volume control so I can use the Powermate?
Please don't advise me to buy a DAC with an analogue volume control....
Thanks in advance!
Wim de Gelder
