Author Topic: Few minor ui improvements  (Read 44585 times)
mikebo
I did a quick mockup to illustrate what i mean
http://i.imgur.com/36MJg.png
1. Give the search and address field a 1px rectangular border.
2. Get rid of the icon for 'now playing' list. It's unnecessary and when you open 'now playing' in the main panel the icon in the right panel stays even though there's no 'now playing' list anymore.  as ma_t14 pointed out it serves a function
3. Make the headers of track browser (and now playing list) look like the headers below it.
4. If there is nothing to scroll hide the scrollbars.
5. Make the selection in navigator panel full-width.
6. Replace those expand buttons with arrows.
7. Get rid of the now playing/selected bar. Instead change it through right-click menu (same in lyrics panel).
8. Display a notification with remaining time if user activates the auto-shutdown. (also can you add a option to shutdown when a current song finishes, this would be very handy for lengthy podcasts)
Good ideas? Bad ideas?
Last Edit: May 08, 2012, 09:42:35 AM by mikebo
ma_t14
The icon acts as a toggle for auto-dj, so no, its not unnecessary.
Makes sense and space is conserved. +1
Looks better +1
I like this idea, it certainly looks more elegant that way. +1
I don't agree with this. I want to know immediately and at any time whether the artwork/details are for the playing or selected track
+1
Overall I think most of your ideas are great. Good work!   :)
Last Edit: May 07, 2012, 06:43:59 PM by ma_t14
just regarding 5, i have tried this and its easy enough to do - the reason i didnt go ahead with it is it really needs a different set of colours for quite a few of the skins and some of the skins are no longer being updated.
I guess what i could do is make the full width selector a skin setting so that way it will only be set by the skins that are being maintained
mikebo
I don't want the scrollbars to be hidden completely. Just the arrows and the thumb, like in the mockup, this way we avoid reformatting of the columns.
ma_t14
Oh, okay.. Yes that makes more sense
i've done 5 as a skin setting
  <element id="FullNodeSelect">true</element>
this has
4 - scrollbar is now not displayed when there is nothing to scroll (i only have time for a small amount of testing so its possible its not working in all cases, so let me know if it doesnt work in all cases)
5 - full width selector bar on the left navigator panel when set in the skin
not yet done for the Library Explorer
http://musicbee.niblseed.com/V2/MusicBee_Exe_Patched.zip
mikebo
Looks great. One tiny thing though: in track browser when switching between views where the visibility of the scrollbar changes, musicbee flashes the regular window scrollbar next to its own.
edit: also the area behind the scroll thumb is a little darker http://i.imgur.com/O8JpP.png
edit2: the scrollbar issue seems to be due to ScrollBarMargin set to value other than 0
Last Edit: May 09, 2012, 05:58:34 PM by mikebo
i would think the scrollbar flashing has always been there and i've put in some handling so it should no longer flash (at least for the scenario i found it happened - there might be other scenarios, so if you find it still happens can you give me detailed steps)
I will post a update later
ma_t14
I really like the idea of having arrows instead of plus signs in the computer node. It looks far more elegant and modern that way. I find the plus signs don't blend well with darker skins.
Steven is that change on the cards?  :)
Iowaseven
Thanks for the improvements, Steven! How about as a quick one, the option to hide the navigation bar/search box area, for those of us who don't use it?
Regarding the auto-dj icon button; wouldn't it be a lot neater just to have it as a button in the player controls?
Last Edit: May 10, 2012, 07:27:13 PM by Iowaseven
