Author Topic: Sync Lyrics  (Read 2221 times)
vinki
I have few requests about synchronized lyrics:
1. Fix edit window. Print screen is here (http://s15.postimage.org/410s24sw9/lyrics.png), problems are marked in red.
2. Add support of extended format (more info here: http://en.wikipedia.org/wiki/LRC_(file_format) ), so that Male, Female and Duet would be in different collors.
3. Fix synchronization (example here: http://www.2shared.com/video/6wNhLofP/Lyrics.html , for me it plays only in WMP). I have synchronized some songs myself and I have done it very accurately, but now each line gets bolder few second before it's actual time stamp.
4. Implement flowing lyrics as in MiniLyrics.
Last Edit: May 07, 2012, 07:48:40 AM by vinki
for 1, i can only reproduce this if you resize the window when editing is active. Is that what you did?
If i resize the window then edit, its fine
vinki
Yes, you are right about 1 - if I resize lyrics window when editing is enabled, I get that strange look. However, text within buttons still does not fit.
