Author Topic: Disable Menu Bar in Caption Area  (Read 12893 times)
this issue is completed unrelated to the menu text clearness.
I have made one more attempt at this (i dont want to install anything that changes the windows system files so wont install the custom theme)
http://musicbee.niblseed.com/Patches/MusicBee.zip
if it still doesnt work (could you let me know), then you can edit MusicBeeSettings.ini
- exit the new MB version
- it will add on the 18th line
<SystemDisableGlow>false</SystemDisableGlow>
- restart, Help/Support/View Settings file
- keep the file open
- exit MB, and change the value to true and save
- restart and the text should not glow
Kaelri
Here's what I get with the new patch:
When I disable the glow in MusicBeeSettings.ini, I get:
Actually, I sort of like it that way. :D But I think the best solution would be to go back to the previous behavior, but allow users to manually disable glow in MusicBeeSettings.ini, if they so desire. (It obviously doesn't merit a place in the preferences GUI, since this issue probably affects only a tiny minority of users. I certainly don't mind doing a little plaintext tweaking.)
Thanks again for spending so much time on this. Your attention to detail really sets MusicBee apart.
Last Edit: May 05, 2012, 10:12:30 PM by Kaelri
hopefully this version should use the correct text colour when glow is disabled:
Alexis
Hi Steven
With this  change... if autohide is enabled,  it does not work on hover when in theatermode, so the 'close' button id not present.
update:
And on escaping Theatermode... it would  then not work in the main player unless the player is restarted.
Last Edit: May 07, 2012, 03:48:20 PM by BeeFanatic
mikebo
I'm also having issues
there is a bright line across caption and the gap between menubar and panels is now bigger.
this should fix both the reported issues:
http://musicbee.niblseed.com/V2/MusicBee_Exe_Patched.zip
mikebo, i dont know how to get the glow exactly like windows does - i am following the microsoft suggested approach but it is a little different
Alexis
Thank you Steven.
mikebo
Thanks, it's fixed. Don't worry about the glow.
Another problem I've noticed is that the window decoration (aero glass or whatever) flickers black when the window is maximized.
it should be barely noticable now, however if too many glitches keep getting reported with this i might just revert to using the standard windows functionality for when the menu bar is docked below the caption bar. All that will mean is the application will need to be restarted when switching the menu dock
mikebo
i decided to change it so when the window borders are not skinned and you have the menu displayed below the caption bar then it will use the standard windows caption bar. The only small downside is MusicBee will need to be restarted when changing the menu dock. This version should also remove any flicker when the menu is auto-opened/hidden in a windows glass caption bar, with the small downside that when resizing the window will show black flickering when the menu is auto-hidden only. None of the above applies for skinned borders
Last Edit: May 08, 2012, 10:31:41 PM by Steven
