Here are some features that would be nice to see improved on the Disc Burner:
1. Support for 80 minute discs.
2. I know it shows the stats of the files in the upper right but a more visual progress bar showing the amount used is a visual enhancement.
3. Having the disc burner load as a window inside the main application for easier drag and drop.
4. An add to disc burner option on the right click menu or send to sub menu.
5. A spot to set the normalization percentage instead of just a check box for level volume.
6. I assume CDTEXT is always written but I did not see it when I put the cd back into the computer.
