Author Topic: Column Fields Layout Presets  (Read 5400 times)
beehive
I not sure if it is possible already or if this has been requested before, since I also have a hard time wording the subject.
What I was thinking is to have the ability to save presets to the layout of the column fields in the album and tracks and tracks detail layout view.
For example in album and tracks view when I'm editing and scanning through files I like to have the sample rate, bitrate, time etc.  in the column fields. But when I just listening to tracks personally I prefer to just have the  Artwork ,Album, Artist etc as fields. It would be great if you can save a column fields layout to a preset so that you can switch between multiple column fields layouts when needed.
This would be similar to the Define Custom Sorting command except you can Define Custom Column Fields Layout.
i am guessing this is not ideal for what you want but may be useful
View/ Saved Settings/ Save Layout Settings To...
and Load Layout Setting From...
can be used to save/load customised layout (including displayed fields)
beehive
Very useful!  Actually this fulfills my wishlist. Thank you
