Author Topic: Also have the field name in tag editor changed when label name is changed.  (Read 6101 times)
jistme
When you rename the label of a field through Fields layout Editor, the name change is not carried on in the tag editor field.
For me personally I would like it when these would be 'aligned'.
This is as much a wish as well as a proposal though, I can also see arguments not to implement this.
When you use the Fields Layout Editor to override labels, these names change in most locations, but not all do everywhere.
For example in the tag editor panel these five are not re-labeled accordingly:
+1 for changing that
LeftHandy13
I would like to change the labels on the Tags tab. Example: conductor to Producer:
I found the list of Tags -> Preferences -> Tags(2) -> Configure Fields...
This puts me on the Fields Layout Editor where I rename the "Override Label".
Then Save.
But my changes are not there?
What am I missing?
Can you remove unwanted fields from the Tabs?
Thanks!
Left
UPDATE: This seems like a bug to me. It is the Field Editor with labels of Original Label and Override Label.
If moving anywhere it should be moved to BUG.
Last Edit: January 13, 2021, 09:20:22 PM by LeftHandy13
Regards: Left.
Hi, welcome to the forum!
Try updating to the patch in my signature. I know this came up recently and I think it was fixed.
MusicMee
Very nice! I was just trying to figure out if I could rename the "Publisher" tag on the editor to "Copyright" and have it read the copyright tag instead.
You won't be able to change which tag frame that reads, only the label on it.  Looks like copyright is already available in the custom tag list though: https://musicbee.fandom.com/wiki/Custom_Tags
