Author Topic: Converted files in inbox?  (Read 3237 times)
V4lve
Hi.
Just discovered that MusicBee doesnt allow converted files to be saved into the same location and the organised library.  Would it be possible to have them show in the inbox so that I can decide what to do with them inside MusicBee?
Ta
no problem to allow add to Inbox. As for the reason i have the restriction in place when directly converting to an organised library - i'm not sure why i put that in! I guess the naming rules would be dictated by the library naming rules being the only thing i can think of. Before i remove that restriction i will think about it some more
V4lve
