Author Topic: WMP12 Skin  (Read 70724 times)
silasje1
Redone the Mini Player so it looks slik. Small color fixes in the player itself
Last Edit: May 28, 2012, 07:26:43 PM by Silas Arentsen (Silasje1)
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
silasje1
New version with:
-New icons (thanks to Mikebo for all icons, changed 2 to the WMP 12 icon)
-NEW BG2 and BORDER added on multiple places.
-Changed some color and inactive colors to be nicer to view.
Last Edit: May 28, 2012, 08:07:18 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
Hotfix:
adds a new progressbar which isnt too grey
fixed a white pixel in progressbar due too a wide image.
sorry for the mass updates im doing :) im going to slow it down now... just big releases
Last Edit: June 01, 2012, 01:36:10 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
azeal
First of all I have to thank you very much for this theme! I always loved musicbee but I liked how wmp looked much more, and now I can't even say it anymore and musicbee is the best of the best  ;D
Anyway, I think the background of the artwork view should be light blue like the others view and not gray, which is a bit out of style with the rest of the skin. Also, I noticed that the play/pause button should bigger than the previous/next buttons, while is almost smaller, and that maybe the red of the lastfm icon is too outstanding and perharps it would look better if there was only the symbol of lastfm and not the whole square. In the end maybe the autodj icon should be smaller to fit best. They're only suggestions though  :) Thank you for your hard work!
silasje1
Your welcome :)
Artwork view grey? it is blue here :) Make a screenshot pointing this out please.
I know the Play/Pause buttons would be alot bigger indeed ... but i dont think it would look good due to the small player bar height
The Last.FM icon i made is either had or like :P sorry wont change that
AUTO DJ icon? you mean the shuffle etc button? it is the same afaik
Dutch Translation
WMP 12 Skin
azeal
Your welcome :)
That's what I mean:
Here's blue
and here's gray (artwork view, sorry, that's italian)
You're right about the play button.. maybe it could be resized the next/previous buttons then? o.o
Ok for lastfm xD Is it possible to change it myself?
Yes, that's what I mean, I see that on other skins looks a bit smaller
Last Edit: June 01, 2012, 12:53:16 AM by azeal
silasje1
I see the grey color now yes. Will be fixed.
You can make the last.fm icon smaller by using the source download link. It should be clear enough what to do than
Dutch Translation
WMP 12 Skin
azeal
Thank you very much, I'm looking forward to see it :D
silasje1
Updated:
1 June:
-Fixed gray background in album view
-Fixed some more small bugs in album view
-A bit lighter track color now
Edit:
-Removed some borders to make the top adress bar look smoother.
Download is in OP
Dutch Translation
WMP 12 Skin
azeal
Thank you, that's great :) though I liked the previous track color best xD (but that's just my taste)
silasje1
SMall fixes:
-Added support for the menu button
-Reverted track color
download is in Topic Start
NEW source!
add new screenshots
Last Edit: June 11, 2012, 06:58:21 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
Nikkel
silasje1
Great to hear ! Please report any questions or  bugs ;)
Dutch Translation
WMP 12 Skin
VX
I don't like WMP12 nor use it, but this skin is simply great  :) It's very professional and well designed.
It deserves to be distributed with MB 2.0 as it could help some newcomers to switch form WMP to MB.
Thanks Silas  :)
silasje1
Thanks for the love man! Im still liking the Skin and use it for daily use. Just need to update it if there are updates. But it is very stable (? ehh well finished)
Dutch Translation
WMP 12 Skin
