Author Topic: WMP12 Skin  (Read 64364 times)
silasje1
first off i think what you have done is great but for my tastes the use of blue is now too much.
But colour preferences are a very personal thing and if you feel it is right then stick with it! Having a look WMP just now they make use of black. I dont know if that would work or not with your skin, but maybe worth trying out
I will need to tweak the library blue to something lighter blue. Wmp12 uses blue as primary color. Wmp11 uses black. Already planned on doeing a black version too
just to be clear, i am just suggesting to try making the column headers black not the whole skin
Ahh ok... i will make a dark version for the 'lovers' WMP 11 has a black layout and WMP 12 Blue...
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
silasje1
As good as finished:
Download in TS
no big changes just color fixes
Waiting for skinned borders  :)
Not really my taste... WMP12 uses windows buttons itself... so see no good point on using them... but please enlight your opinoin so you would convince me?
Last Edit: May 24, 2012, 01:36:27 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
looks good - it has a nice light feel about it. Only suggestions would be when you have multiple tabs open (horizontal - vertical looks good), the background for the tabs bar doesnt fit in my opinion. Also the whole x button in a tab blacks out on mouse over which doesnt seem right.
Is it intentional that the library explorer header is black? It looks good but its the only panel that uses black that i could see
ma_t14
Please add this to Musicbee. I think it is finished.
Download is here:
http://www.mediafire.com/?20e0c8in9r2yhq4
There is no highlight when selecting nodes in the left side panel. (e.g Music, Inbox, Playlists etc)
silasje1
Fixed the highlight part and auto centered the current track name. Please give some feedback since it seems to have some rough edges
Download in TS
-Updated topic start with new images and changelog
New update!
Last Edit: May 24, 2012, 01:36:40 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
ma_t14
http://www.mediafire.com/?iars335sca8sjh1
Can you please make it so that is uses the new "whole line" hightlight? Thanks
Also the colour of the love button when you select a track should not be red if the track is not loved... It's a bit misleading this way  ::)
Last Edit: May 17, 2012, 11:43:24 AM by ma_t14
silasje1
Download in TS
Fixed:
Download in TS
Someone has a good testimonial :P?
Last Edit: May 24, 2012, 01:37:05 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
Yes, I have. ))
Would you share it?  :D
edit:
added new screenshots in TS
Edit2:
Download in TS]
Fixed pause button being a bit too big :P
Last Edit: May 24, 2012, 01:37:18 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
Fixed a Auto DJ header color problem and added default autodj icons (havent seen them in the player at all yet but they are there)
Downloads in TS
Last Edit: May 24, 2012, 01:37:29 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
Well done Silas  :) I'm enjoying it!
Im glad you do :) Thanks for the love ;D
Dutch Translation
WMP 12 Skin
silasje1
Latest update!
I reccomend updating with newest MB update.
Download in TS
Source will be up in a bit ;) Show me some love :P
Edit:
Source is Up!
Also added new screenshots in TS (topic start)
Last Edit: May 26, 2012, 11:11:19 AM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
silasje1
Fixes a Offset problem in the Shuffle icons.
Also new Auto DJ icon
new source:
download in TS/OP
Last Edit: May 27, 2012, 08:13:17 PM by Silas Arentsen (Silasje1)
Dutch Translation
WMP 12 Skin
