Author Topic: Dummy skin or how to change the colour of an element  (Read 46321 times)
jistme
I can't get these stars to change color.
Following the color in your sheet it should be:
<element id="Player.StarRating.Default" fg="196,197,197"/>
but changing the value doesn't change the color.
(also I notice it is under the header \\ --- NOW PLAYING POPUP), but this printscreen is not from a popup?
lnminente
Verified here too. So i did this:
Starting from the beginning of the file i search for .StarRating
Then i found a element ending with .StarRating.Hightlight which is not present for elements starting with Player.
I created the element Player.StarRating.Highlight and gave it a value of a very different color from the others, for example 255,0,0
So it seemed the 196,197,197 started to work again when changing it
This is what i added <element id="Player.StarRating.Highlight" fg="255,0,0"/>
jistme
My eyes are square, gonna call it quits for today.
If interested, here is the current result:
http://www.mediafire.com/?58999o1u3y3e1
My two main challenges for the moment:
- can't get the star rating fixed (will try again later this week)
- still a slight difference in color in the side panel player D(ark) L(ight)
Thnx again for your great work and help!
Last Edit: July 06, 2012, 08:56:42 AM by jistme
lnminente
That's nice, you have done a lot in only one day!! :o
I would use variables for making easier in a future changing some colours  http://getmusicbee.com/forum/index.php?topic=6203.new#new
Last Edit: July 04, 2012, 01:40:56 AM by lnminente
jistme
Thnx, your tools and tips made it possible.
The link to the new SkinCreator is dead, it looks like Steven removed it from nblseed.
jistme
Strange, that solution works in your dummy xml, but not in mine.
Probably the rating colors are overruled by some other setting in the sheet. It's beyond me.
Anyhow, I am already quite happy with the result:
Last Edit: July 04, 2012, 01:12:48 PM by jistme
jistme
I solved it, I know how, but I don't know why?
These three lines were somewhere in the beginning of the xml sheet (lines 118,119,120):
<element id="Player.StarRating.Default" fg="255,0,0" />
<element id="Player.StarRating.Lowlight" fg="0,255,0" />
<element id="Player.StarRating.Highlight" fg="0,0,255"/>
Changing the color values there have no effect at all.
Then I moved them to lines (200,201,202), and then it works?
I'm confused, so the order is important, but how?
Example skins: ('test fail' and 'test pass')
http://www.mediafire.com/?3vqcql26qwcdd
(use main player non-flat layout)
lnminente
mmm I see, it works the same here.
BTW I have discovered something strange in the midnight skin (so in dummy too):
-The elements Player.StarRating.Default and Player.StarRating.Lowlight are defined two times, one for "Players" and another for "Now playing popup". Don't know if its a bug or if it has one reason for being there :/
OrB
I see. As far as i remember there was a problem to make it work. (sorting/moving some lines up/down as jistme noticed)
so i dont think its an error to see the first occurrence as a kind of initialization. (fg="0,0,0")
But maybe you can find out a better way   :)
lnminente
Updated with the following changes (link in first post):
Changed bg in PlayerSidebar.Control.Default to 255,30,27"
Player.StarRating.Default and Player.StarRating.Lowlight are present only one time now
Removed alpha channels
Added the latest new elements
Last Edit: July 06, 2012, 11:20:18 AM by lnminente
jistme
Great!
two remarks:
- lines 83 & 85 seem duplicate
- these two might be handy:
<element id="MiniPlayer.StarRating.Default" bg="125,125,125" fg="175,175,175"/>
<element id="MiniPlayer.StarRating.Lowlight" fg="50,50,50"/>
lnminente
They are actually present in lines 151 and 152 having these values:
<!-- 99--> <element id="MiniPlayer.StarRating.Default" bg="141,136,126" fg="223,228,229"/>
<!-- 100--> <element id="MiniPlayer.StarRating.Lowlight" fg="51,57,56"/>
I'm going to take a look for keeping only one of the lines 83 and 85, thanks
lnminente
I have fixed it too and created a collaborative online document with the colours part of the dummy skin. Anyone should be able to editing it for any improvement. It's here: http://piratepad.net/U1JHY5UGcZ
jistme
Sorry, missed that, xml brain overload ;-)
