Author Topic: Exposing the playlists  (Read 3685 times)
V4lve
How about making the smart playlists available as m3u files so my media server can use them.
m3u files cant directly support smart playlists - they are just a list of files. What i can do is allow you to save the smart playlist as a m3u file.
Currently the only way i can think you can acheive this is to create a new playlist, and then drag the files from the smart playlist into the new playist.
The new playlist will be a m3u file located in the Playlists sub-folder of your library
V4lve
Actually.  I'm being a bit stupid.  My media server (Firefly) can duplicate the smartplaylist functions so I think I am OK.  Just need to test that it works when i ask it to scan MusicBee's playlists folder.
