The list of songs is something that Greb has done specifically for his theme. The main difference to the Now Playing Assistant is the look fits in with the rest of the theme, but of course lacks any of the playlist manipulation functionality which is the point of the Now Playing Assistant. Maybe you could ask Greb to consider a way to open the NPA from the list of songs panel.
For the NPA, i am making some minor changes and will include the request so it automatically jumps to the playing song when opened
Difficult to do, something like that. Perhaps it could be possible to forward until a specific song in the list telling MB to advance X songs if you click in the title of the song corresponding to 'Track[X]'...
BTW, is there a way to open the Now Playing Floating Window from the TheaterMode? And how to close it? (onClick="CloseTheatherMode" or onClick="CloseWindow" don't work
And a small request: would be it possible to add 'Conductor' as a field in the TheaterMode? ('Conductor' is the closest tag to 'performer', that doesn't exist).
