Can you fix the invisible Panel Layout and Search buttons on Dawn? (Maybe fiddle with the colours of all the buttons in that area, the inactive ones look active and vice versa) It's otherwise my favourite skin.
There's not much i can do about it. I could make the background darker like in the default skin.
I have some ideas for redesigning the toolbar but i'm holding them off, because i've made a lot of requests recently and don't want to overwhelm Steven.
you can override the default colours for the panel buttons using:
Panel.HeaderButtonOverride.Default
Panel.HeaderButtonOverride.Disabled
you can also override the search box width adjuster line:
Controls.SearchBoxSplitter
you may as well make the layout suggestions now as i am considering incorporating one of blinghounds suggestions and its best its done together
