Author Topic: [MB2.0] Supported video formats  (Read 7819 times)
butty
If you are going to add video formats, please consider the following ones:
- MPEG2 HD TS (Japanese Digital TV format)
- DVD
- Blu-ray disc
Thanks in advance.
butty
ma_t14
Why not install a codec pack?
The library is third party... I think Steven cant do anything about it  :-\
butty
Thanks for the info.
I have installed "K-Lite codec pack" and "Satsuki decoder pack", however, none of the three formats are handled by MB.
No way...
cartman005
"DVD" and "Blu-Ray disc" aren't really video formats. They aren't stored as individual video files and I don't think that they are something that is MusicBee is meant to be used to play.
silasje1
Use VLC as external media player. This allows the Bluray to be played
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
butty
Blu-ray's files cannot be added to "Video" of MB.
i will include ".m2ts" as a video extension. Any others you are aware i am missing?
butty
Thank you.
Please add ".ts" (MPEG2 TS).
And, would you try ".ifo" (DVD) and ".bdmv" (Blu-ray)?
.ifo is already in the list and i have added the others
butty
Thanks.
I see, I was wrong. IFO files can be added to "Video", and can be played by an external player.
greenday1987
  • Long live OiNK!
MKV/x264/h264 doesn't play for me. I've installed any codec packs yet though
RIP OiNK
Maleko12
.m4v plays the audio, but not the video. Related to this, if one goes all the way to the end of a .m4v video, when it tries to go to the next video, MB crashes.
sounds like an issue with the codecs you have installed. Suggest you just use the external player functionality if you are not willing to install a codec pack such as k-lite
Maleko12
I have installed k-lite before getting into MB 2.0. I'll probably just use that external player functionality that you mentioned.
ma_t14
I experienced a similar crash when playing mkv files if I remember correctly
