Author Topic: [MB2.0] External video players  (Read 5377 times)
butty
Hi!
It would be better if multiple external video players can be specified in "Player/video player" pref.
Because some video format requires special players - eg. Japanese TV's MPEG2 HD TS files cannot be played fully with "popular" players, such as vlc.
So, I suggest that adding one more opthion, such as "use Windows' player settings", which invokes players through Windows associated with the file type.
Regards,
butty
ma_t14
Have you tried PotPlayer? It's the most advanced video player out there currently in my opinion
http://www.videohelp.com/tools/PotPlayer
butty
Thanks ma_t14!
PotPlayer is great. It seems to be able to play Japanese TV's MPEG2 HD TS files.
I'll check it using more videos later.
Mikelap
[/quote         If you have a chance ma_t14 could you  explain how to install  pot player in musicbee . Thank you.
PC Windows 10>Musicbee>Quad 405>Burson Conductor >Pioneer SX750>Woo Audio22>FLUXION AV-7 S.E.T. Speaker amp>FU32+6N2 AMP.>Asus Essence STX>CmoyBB>Sennheiser HD800S >Grado RS2E>DENON LA-D5000 LITE >DENON AHD-1001,Kef 104,Klipsch KG 5.5
ma_t14
Just configure PotPlayer to be used as an external player. It's under Edit>Preferences>Player> Under video player choose "use external player:"
if you are using vista/7 and the 32bit version of potplayer it should be here: C:\Program Files (x86)\Daum\PotPlayer\PotPlayerMini.exe
Mikelap
In Musicbee i got  the sequence( C:\Program Files (x86)\Daum\PotPlayer\PotPlayerMini.exe) its in the box next to ¬®use external player¬® but how do i start it  in Musicbee or you have to enable the player from the file ? Thanks for your time .
ma_t14
First you need to have the video plugin installed and enabled, its found here: http://getmusicbee.com/forum/index.php?topic=5817.0
Then enable it in preferences/plugins if not already enabled.
When you double click a video file in MusicBee Potplayer will open instead of the in-built video player
Mikelap
My problem is in VIDEO , CHOOSE LIBRARY when i choose the one where the video files are Musicbee crashes any ideas !
