Author Topic: Autoselect added songs  (Read 2358 times)
voon
Maybe I missed the option, but: It'd be nice, if the songs I just added to MB by drag and drop automatically get selected in the list ... so I can immediatly fix their tags, move them etc without a manual selection again.
cartman005
I would recommend that you drag-and-drop new files to the Inbox first so you can edit their tags. Then add them to your library when you're done.
voon
What's the advantage? Apart from having new songs grouped elsewhere that is.
cartman005
The other advantage is the songs aren't auto-organized. I use it as an area to put music that I'm not sure that I'm going to keep.
I know it doesn't specifically address what you want but it seemed like it might work as a partial solution to your issue of fixing tags when you import new music.
