Author Topic: Support for MIDI playback  (Read 11667 times)
Cypher
This option keeps me away from Musicbee for a couple of months and since there's a file called "bassmidi.dll" in the Musicbee folder, why don't make it functional?
Thanks,
Cypher
Last Edit: May 05, 2019, 08:10:58 PM by Cypher
Cypher
BUMP, i hope it will be in the next weekly build.
silasje1
i can't playback MIDI neither. But why would you want to play those?
HDMI GTX570->YAMAHA RX-V471->DALI ZENSOR 1
Dutch Translation
WMP 12 Skin
adding MIDI support is not trivial and i cant believe it would be important to many people so i havent decided whether to add it or not. But in any case i wouldnt be able to look at it for a number of months so you best use another player that supports it if its important to you.
Nokiaman
Sorry for bumping, but I wish to see this too.
Nokiaman
Odd. Doesn't work for me on latest patched version.
Did you install a sound font file?
Nokiaman
Yeah I just did and it works. There really should be some basic one OOTB.
I agree, that'd be a good addition for 3.1
ShinMak
On earlier versions of Musicbee, I have been able to play Midi files.
Now I am trying to play Midi files with the latest version and it's not working.
My computer has not changed, neither has the software.
Just wondering what could have happened.
I have not adjusted the settings either.
Every other program seems to play Midi files with no issue, only Musicbee has stopped playing Midi files.
The audio track will iterate through the audio timeline but no sound can be heard.
I've looked at the volume mixer and all the volume settings are as they have always been, I've tried setting everything to maximum volume and still no sound.
Any suggestions/help would be appreciated very much as I like to use Musicbee when organizing my Midi files.
ShinMak
Solved it.
The Midi SoundFont is blank.
Never noticed this setting before.
So I guess I'll have to find a soundfont.
ShinMak
Actually, didn't solve it. Even with a soundfont there is no sound. I give up.
can you send me a link to one of the files you are trying to play
