Author Topic: Reflect that custom search is active  (Read 1952 times)
junebaug
I'm missing - or I simply don't see it - a visual reflection that the custom search is active.
Also it would be nice to get the 'x' mark in the Find entry-field right at the very top row of the main pane to simply delete the search, as it is if do a simple search by this field.
With kind regards
 Ralf
i've implemented now so its consistent with right click/ Search/ Find ...
the header displays the filter and you can click back to go back to the original fully populated panel
junebaug
Hi Steven,
great solution, way better than what I had in mind.
May I lend your attention to my other "selection"-wish:
 Track browser with filter for "Album OR Track artist"
from december 18th?
A short note if or if not in the pipeline would be much appreciated.
Regards Ralf
junebaug
thanx for commenting Steven.
Anyone some better ideas to do that task than to go through custom search?
Ralf
