Thanks for your reply,
sounds good, I will look forward to future releases
I played with Musicbee some more and found a few more things I'd like to note..:
- the search field doesn't allow the use of ctrl + a to select all text
- Replaygain scanning for WMA is not supported as I see. Is reading of WMA RG tags supported? They don't show up here.
- In preferences: "turn on scrobbling" is already checked. When I uncheck it MB asks for my login. Shouldn't it just uncheck?
- In mini mode: when the preferences are opened from the mini mode context menu they always appear below the window. I have the mini mode window put on the taskbar on the bottom so the preferences window appears mostly off-screen.
- I found a few files in my library that show garbled text for some tags. Can I send you some sample files somewhere?
- When I select an available option for hotkeys, set some key and press "delete" before I assign the key the following error appears:
MusicBee v1.1.3544.12681 (Win6.1), 26 Sep 2009 20:56:
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei #=quKhs69E8Lir$jr7iFgGHHDOqvayCPPtbDiz$rsrvMnvGpYKom_h7sd5TdXysT2Bx.#=qXOV1epexpZ0BGB81M22J7BqnYfQddFzmYNEtdJDPJ6M=(Object #=q$pT9ugM$JarRIwPQaFeU1Q==, #=qJWdiUuJ2w$pceHbBW5mRYo6jmmkS7btzdoqRaqY7liXxr9MGt0A$1o3RiklhYagr #=q7cHhTu6N21P4g_fzn7mWAA==)
bei #=quazrxFQr$szhc5yig$dohxeb__PcHWf3hryEAAkf_AAhi9Qij$ni$BVyBsA9wRjE.OnClick(EventArgs #=qhzSPmOf_OdW8M7TY57fzLw==)
bei #=quazrxFQr$szhc5yig$dohxeb__PcHWf3hryEAAkf_AAhi9Qij$ni$BVyBsA9wRjE.#=q3O2BsKbhmais8$fvgWAeU7E1OKizoLKDdnP6zL2uXdM=(Object #=qIzyYqRZeqe6nmBNB__dNWA==, EventArgs #=q18eTTC9VX2ID2YAFgNvSvw==)
bei System.Windows.Forms.Control.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
bei System.Windows.Forms.Button.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Thanks for your time and have a nice day
