Ok, here is the error log:
9/20/2009 12:30:47 PM - 1.0.3429.14496 - System.InvalidOperationException: There is an error in XML document (366, 43). ---> System.InvalidOperationException: Instance validation error: 'ToolsAutoTagAlbum' is not a valid value for ApplicationCommand.
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderApplicationSettings.Read1_ApplicationCommand(String s)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderApplicationSettings.Read9_KeyCommandPair(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderApplicationSettings.Read21_ApplicationSettings(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderApplicationSettings.Read22_ApplicationSettings()
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader)
at #=qEUR2W6Zr1b7FqjR9ekqVmtHc$DuMy0S_D$l$E7Mrle0=.#=qmRO357dwmCPWrMDf4tIvIA==(#=qjks2mcIp2nQLeyWuxQxlEbzTza9j4JBwA5tHobvCtKY= #=qoM9b6ghIUYcykrCKh4Qkog==)
at #=qEUR2W6Zr1b7FqjR9ekqVmtHc$DuMy0S_D$l$E7Mrle0=.#=qaCv_KXDMXDvA9BgsC9W7Vg==(#=qjks2mcIp2nQLeyWuxQxlEbzTza9j4JBwA5tHobvCtKY=& #=qoNr930T2WnGYGs4ZNWYLNcCdcG2AZ3tqdQBBEGwjHcw=)
at #=qnPRBgFn0C02wNa5u1_tsNXnElX_OoSckNXam2iR9_eM=.#=q_B$nhi9uUUu0mnKbB$MzQ6Akg0khnaJriRFwGhOwshk=.OnStartup(StartupEventArgs #=qHIJ8hURfvHcnNRH96VvwJw==)
9/20/2009 12:30:54 PM - 1.0.3429.14496 - System.InvalidOperationException: There is an error in XML document (366, 43). ---> System.InvalidOperationException: Instance validation error: 'ToolsAutoTagAlbum' is not a valid value for ApplicationCommand.
9/20/2009 12:53:32 PM - Refresh active devices=0
9/20/2009 12:53:32 PM - scan all drives
9/20/2009 12:53:32 PM - initialise non-usb device
9/20/2009 12:53:32 PM - id=C:\
9/20/2009 12:53:32 PM - root folder=C:\
9/20/2009 12:53:32 PM - id=Z:\
9/20/2009 12:53:32 PM - root folder=Z:\
9/20/2009 12:53:32 PM - checking for network drives
9/20/2009 12:53:32 PM - Z:\ = \\Killzone\MP3\
9/20/2009 12:53:32 PM - checking manually mapped unc paths
9/20/2009 12:53:32 PM - checking for MTP devices
9/20/2009 12:53:32 PM - no MTP devices detected
9/20/2009 12:53:32 PM - load settings
9/20/2009 12:53:32 PM - Refresh completed, active devices=0,added=0,removed=0
