Author Topic: beeTunes Skin  (Read 147795 times)
eMDru
I reinstalled again
These are absolutely default settings
What happens with the regular skin:
And now that what happens with your fix:
lol now its messed up again.
Something strage is going on here.
Anybody else using windows 8 X64?
BTW the older version of the skin worked ok but I like the new one.
older version:
are you using a standard screen DPI resolution eg. in the windows control panel/ Appearance and Personalisation/ Display is it set to 100% ?
eMDru
I'm using 125% and it apears to be the problem...
when I switch to 100% it works ok
Can you make a version for 125% DPI?
eMDru
It Works!
Thanks alot man you are the best 8)
delpinsky
Hi there cartman005,
since your skin is my favourite, I wanted to ask you something, about a feature that I don't know if it's available, that I posted also on the Theater Mode forum.
Is it possible to ADD the image of the CD Case for the Album Arts?
I was thinking about a png file of a CD Case as layer. to recreate something similar to what AlbumPlayer does.
http://www.albumplayer.com/features.htm
Thanks again for your great work!  :)
Last Edit: November 11, 2013, 09:23:40 PM by delpinsky
cartman005
Sorry, I haven't checked this thread in a while. But no it is not possible for a skin to include a feature like that. That would be something that the developer, Steven, would need to implement.
cartman005
Hi guys, I have updated the first post of this topic with a new version of this skin, modeled after iTunes 11. The old version, which was based on iTunes 10, will now be called "beeTunes Classic".
Stimulator
Hi cartman005!
Today I registered for this forum especially because I want to say Thank You for this wonderful skin (beeTunes Classic), which I love to use since a long time now. For me it is by far the most aesthetic skin for MB. Unfortunately most of the other skins are sometimes really shocking terrible so that I wouldn’t know what to do without it.
I also will never more dispense with MB. ;D
Cheers
Stimulator
PS
The beeTunes skin (not classic) isn’t working wright.  I made a snip but can't see a possibility to attach this...
Last Edit: February 12, 2014, 08:55:19 PM by Stimulator
you need v2.3 from the first topic on the forum for the new beeTunes skin
cartman005
Please make sure that you are using the latest version if MusicBee because there was a problem with the track info text which is the problem I'm guessing that you are having. The issue is discussed here http://getmusicbee.com/forum/index.php?topic=11758.0.
Also, here is a link on adding a screenshot if you still need to http://getmusicbee.com/forum/index.php?topic=3998.0.
Stimulator
I have version 2.3.5133 installed on Win8 x64 Pro
Last Edit: February 12, 2014, 08:53:36 PM by Stimulator
You can always find the latest version here: http://musicbee.wikia.com/wiki/Latest_Update
Stimulator
OK Thank You!
In the first instance 2.3.5133 and 2.3.5153 looked identical to me… -
I updated but now still one little glitch is to observe at the top left; ‘MusicBee’ letters on the Drop Down-Menu is a bit smudgy (only beeTunes skin NOT classic)
