Author Topic: beeTunes Skin  (Read 147796 times)
cartman005
Yes. To do this, you have to change the color values of Panel.Body.Lowlight in the skin source file to match the values of Panel.Body.Highlight.
If I understood what you want, this should be it.
Lightblur
thank you! =)
now how can I open the source file? because the extension is .xmlc and I don't have any program that can open it =P
Hi, cartman005. I am the one who guided Lightblur to your thread. I think what Lightblur wants to change is bg value of Content[TrackDetail].Body.Lowlight so that it's the same as Content[TrackDetail].Body.Highlight. Perhaps Content[Artwork].Body.Lowlight, too, for artwork view. That's what I understood.
cartman005
thank you! =)
You can't open that file directly. You have to open the source file that is in the .zip file on the first post of this thread. But that's a lot of work so I did it for you. But as redwing pointed out, I did the wrong value. I was thinking you meant a different highlight.
Here is the corrected file. Just download it and place it in the skins directory of your MusicBee installation (most likely C:\Program Files (x86)\MusicBee\Skins). Let me know if it is what you were looking for.
Lightblur
You are almost there I would like also that if I click the blue doesn't disappear, no matter what.
Is it possible?
However THANK YOU SO MUCH for doing this!!!!!!! <3  :D
cartman005
Do you mean when you click outside the bounds, for example where there is not a track in Album & Tracks view, the selection and the selection disappears? If so, I can't change that. This is the behavior of MusicBee.
Lightblur
I see.. well no problem, thank you very much for helping me!!! =))
eMDru
First of all I want to thank you for this amazing skin.
It sure makes musicbee alot more pleasent to work with.
But I have 1 issue that bothers me:
The progress text gets out of the stroke and just not in place.
I tried to fix it by myself and searched for hours but couldn't fix it lol.
Can you do something about it?
Thanks =]
cartman005
Hey, I'm glad you like it. I can try to fix that problem this week.
I'm having trouble replicating it though. How do you get that to happen?
Last Edit: July 02, 2013, 02:09:32 AM by cartman005
i think its to do with the large font size used and will need a correction in MusicBee itself
Last Edit: July 02, 2013, 07:48:54 AM by Steven
eMDru
No, actualy thats because I played with the settings trying to fix it.
I reinstalled musicbee and it happens again.
I'm using windows 8 64bit if it matters.
this version of musicbee should fix the issue:
http://musicbee.niblseed.com/V2_2/MusicBee_Exe_Patched.zip
unzip and overwrite the existing musicbee.exe where it is installed
eMDru
Thanks for helping.
It fixes the left text but the right one is still out.
It's ok when I choose a smaller general font.
even though I preffer the font 10 size I can use it with 8.
Thanks  ;D
can you post a screenshot as it works fine for me
also your first screenshot is a bit weird in that the track details text should be centered. What is the modification date of the beeTunes skin you are using?
Last Edit: July 02, 2013, 10:08:40 PM by Steven
jackuars
Great skin. This is now my default one. I like rounded buttons.
