Author Topic: beeTunes Skin  (Read 144553 times)
cartman005
Can you update the guide to configuring MusicBee to match the layout in the screenshot please, I would like to use this.
The link on page 7 no longer works http://getmusicbee.com/forum/index.php?topic=13799.0
Hi, sorry I'm just seeing your question. Which screenshot are you referring to? It's been a while since I've messed with my MusicBee configuration settings but I'm sure I could help you figure it out.
Koy McCloud
Just downloaded the skins myself, really like them, but I can't seem to quite get the layout to match yours. I see there's a import export layout option, wouldn't you be able to export your layouts for each skin, and upload them for people to download?
cartman005
Good idea. Please see the new link that I added under beeTunes 3 on the first post. Let me know if it works.
Koy McCloud
Did it! Works perfectly! Could by any chance I get the Classic Beetunes Layout please? Also thanks, works great! :D
cartman005
Added, although it won't look exactly like the screenshot since MusicBee has changed a bit since it was taken.
Koy McCloud
