Author Topic: Lyrics Plugin  (Read 153439 times)
the very first post contains the link - i have now removed the .net2 version to remove any confusion
tugengsta
Thank you alot for the plugin. But I have a problem: it still doesn't find lyrics for all songs, though the sites have the lyrics. Any ideas of fixing this?
juanchodeville
Please add musica.com spanish and english lyrics
tompeto
Moshi_
  • http://www.last.fm/user/Moshi_
Please, try to add http://www.lololyrics.com , it is a massively popular site among listeners of electronic music (house, trance, hardstyle, dance, dubstep, ...) and it has almost 20,000 for electronic music only!!
Here's also API: http://api.lololyrics.com/
Last Edit: April 03, 2013, 10:33:43 PM by Moshi_
Moshi_
Xyzzy
Which of the currently available sources (Lrc123.com, AZ Lyrics, chartLyrics.com, LYRDB, Dark Lyrics, Lyrics Time, Lololyrics, Songmeanings.net) provide synced lyrics?
last time i checked only Lrc123.com
not sure about Lololyrics
mikicr2394
Hi!,
I would love to be able to put,
If it would be possible to put two source of lyrics: http://lyrics.wikia.com(That's a good source because everybody can put some lyrics) and http://www.maxilyrics.com (The database of www.lyricsplugin.com 8)) please, for a complete ultimate audio player. Not all songs we have are commerical... because never see the lyrics of that songs, if I can put some lyrics on lyrics.wikia would be huge! 8)
Thank you Steven! ;D
Sorry for bad english.
MB used to make use of http://lyrics.wikia.com but now they only provide a short summary of the lyrics and you need to view the full lyrics in a web browser
baldor
I am new user in MB.
I used previously MiniLyrics embedder. This plugin downloaded lyrics from a bunch of lyrics sites but we had the option to search manually new lyrics if the current one is not convenient. In this manual search, we can choose LRC Lyrics or TXT Lyrics and test a lot of other lyrics.
For example, I want only LRC lyrics downloaded and not TXT ones. And I would choose wich one is the best compared to my song version (depends on album, live or not etc).
Do your plugin has this possibility?
Thanks
Meshigge
Any good link for this plug in? really want this one and all the links posted here are broken.
I have no trouble downloading it from the link in the first post
