My older sisters occasionally would call me that.
And here we go!
Broham, I've applied the plugins, i see a view of the other ones you had in an earlier version of the plugin. But even if i can't see it, I've rated a few tracks to test the automation, and nothing happens.
Are you sure that you extracted plugin .zip to MusicBee/Plugins folder?
