Author Topic: Album Ratings Averages  (Read 21403 times)
My older sisters occasionally would call me that.
But you are from San Diego? Are you natively English speaking?
Thanks, I think its complete analog to Russian "star'ik"
Maleko12
I'm a native English speaker... San Diego, California (although I'm now in San Jose, California... should update that  ;) )
I thought that San Diego is located in Mexico. Shame on me... :)
Christman
And here we go! :)
Broham, I've applied the plugins, i see a view of the other ones you had in an earlier version of the plugin. But even if i can't see it, I've rated a few tracks to test the automation, and nothing happens. What am I missing? I'm using the beta Music Bee, and Windows 7 is my operating system.
Automation need to be ticked first. Also there is manual mode. That's strange that you don't see new 'Calculate average albums ratings' command, maybe you need to check it in plugin prefs.
BeeBeeKing
I've got 52 presets but I can't see the calculate function you're talking baout, where should it be?
No, 'calculate function' is a 'Calculate average albums rating' command in main menu (alongside with all other plugin commands) added yesterday to plugin, its not the ASR preset. Though ASR presets are also updated today.
Maleko12
I don't see it in there... but I DO see two "Additional Tagging Tools" in the plugin preferences...
Well, latest version is 2.8 - not 2.7. And its very strange that you have two "Additional tagging tools" plugins.
Maybe its issue of latest MB version?
Last Edit: October 31, 2011, 08:48:24 AM by boroda74
BeeBeeKing
Yes well my problem was that i downloaded the ASR presets but didn't notice the plugin update.
That area of the plugin thread is becoming a little cluttered, so just overlooked it. Thanks anyway.
Maleko12
False alarm! I realize that as I was testing a version of MB that had .NET4 implemented, and once I deleted that entire folder, everything corrected itself. Sorry for all of that. :-[ :-[
Christman
Somebody help me out here, I don't see anything in my Pref, Plugins area at all. What I am doing wrong?
Are you sure that you extracted plugin .zip to MusicBee/Plugins folder?
Christman
yes, i did. the only difference is that my plugin folder reads "BBplugin" for odd reason.
No, Christman, 'BBplugin' is a completely different folder. You should *create* 'Plugins' folder manually.
Steven, maybe its worth to create empty 'plugins' folder by default during MB installation?
Last Edit: November 02, 2011, 06:13:54 AM by boroda74
