Author Topic: Double-click Lyrics to Edit  (Read 5912 times)
ma_t14
its disabled on synched lyrics if the song is playing
Yes, I think that is the best solution  :)
greenday1987
  • Long live OiNK!
That's pretty epic. I'll get that update copied over later. Thanks alot Steven
It doesn't save the changes when you click away but other than that it seems to be perfect
Last Edit: September 11, 2011, 04:49:56 PM by greenday1987
RIP OiNK
