Author Topic: centering text in track panel information  (Read 1093 times)
monkey
i made search on the forum but i didn't find something about this
is there a way to center text in  a panel (track information panel here)
karbock
No, there isn't.
The only alignment option there concerns the artwork.
  • Heal The World
I cant check right now, but in the preferences screen > tags 2 > configure fields:
One can set the global alignment for specific fields.
The above settings definitely worked in the main panel the last time I checked.
Not sure if it will work on the Track Info panel though, but it's worth a try.
Strength and Honour (2025)
monkey
i tried what you say, but i didn't manage to change alignment neither in Track Info Panel neither in the Main Panel...
thanks for reply
karbock
AFAIK, those alignment settings work only for displays in columns: Albums & Tracks, Tracks.
Thus, with those views in the main panel or with the playlist explorer.
monkey
ok, it's running as you say...
so the possibility of centering text in some panels is perhaps an idea for the wishlist...
thanks
