Author Topic: A more powerful way to browse the library  (Read 10433 times)
i'm talking about the ones at the top of the library explorer ie. Adele .. Pixie Lott
I think the main panel shows Display Artist
greenday1987
  • Long live OiNK!
Okay, I'm probably being stupid then but how do I view it in tag inspector then?
RIP OiNK
ma_t14
The display artist is not stored in the file. It is a virtual tag used only in MusicBee
Last Edit: August 10, 2011, 02:50:32 PM by ma_t14
it used to be a virtual tag but as-of a few months ago display artist is now saved to the music file (its only applicable for multi-artist tracks)
if the question related to using the tag inspector in general, just open the file in the tag editor and then click the tag inspector button
greenday1987
  • Long live OiNK!
Oh wow, problem solved. You were right Steven, one VA album in the library had a space before the artist tag just on some songs. That's great, looks much neater now so I'll be sure to get some use out of this now. Thanks very much :D
RIP OiNK
i've added an option on the library explorer to "Show Similar Artists" so it works with any sorting/ grouping you have as long as Album Artist or Artist is part of the sorting. I've also added "Artist/ Album" as a predefined sort
If you has "Similar Artist/ Album" as the selected predefined sort, its no longer there and you will need to tick "Show Similar Artists" to enable it again
I know it would be better if it showed
Artist
....Albums
....Similar Artists
but instead it shows:
Artist
....Artist and Similar Artists
........Albums (for selected artist)
Last Edit: August 11, 2011, 09:11:49 PM by Steven
Greb
This last update gives some problems. For some reason, it includes 'Tempo' as a sorting element. So you choose Album Artist/Album as usual, and every song with something written in the 'tempo' tag appears as a new album.
does that only happen when "Show Similar Artists" is ticked?
also do you have a custom sort that includes tempo?
greenday1987
  • Long live OiNK!
It works great for me. Looks very good, thanks a lot Steven
RIP OiNK
Greb
Everything is OK. I'm sorry. I was tweaking the custom sort pannel and I didn't realize that 'tempo' was tickled in 'grouping'  :-X
greenday1987, i noticed your artwork layout wasnt handling the spacing for large fonts correctly - thats fixed for the next update
greenday1987
  • Long live OiNK!
Wow, thanks this has bothered me somewhat before but not enough to mention it :)
RIP OiNK
