Author Topic: TitleCase  (Read 364 times)
ChriUwe
Is there an easy way to create "TitleCase" with "Regular Expression"?
Didn't you already ask this in the Additional Tagging & Reporting Tools topic?
If the replies and solutions that you received there don't suit you, the answer will be no.
ChriUwe
That's correct.
But actually every player without a plugin who knows UpperCase and LowerCase should also be able to provide TitleCase.
That's correct.
So actually this is not an honest question but some obscure manner to register a complaint?
Last Edit: May 05, 2024, 04:46:13 PM by hiccup
You've already been made aware of the Additional Tagging & Reporting Tools plugin. If you don't want to use it, that's fine. But I don't see Steven putting any of his time into this when the plugin works very well.
As for Regular Expressions, why would you choose that route when it can be done with the plugin. Your question makes no sense to me.
ChriUwe
This is the current function of the plugin:
$TitleCase5(string, lowercase_words, word_separators, lowercase_words_after_symbols, lowercase_words_between_symbols_opening_list, lowercase_words_between_symbols_closing_list)
How should this function be configured so that I get the following result:
Ndr 1 Welle Nord -> NDR 1 Welle Nord
and
dj Bobo -> DJ Bobo
