Author Topic: extracting Artist name from Title to copy it to Artist tag  (Read 257 times)
monkey
i have a bunch of tracks with a title like this for example :
Aha - Hunting High And Low
i would like to copy the artist name (here Aha) from the title to the artist tag
how can i do that ?
  • Heal The World
Important consideration to make :
Will you want to overwrite the artist tag if there's already an existing value?
Install the AT&RT plugin.
Create a virtual tag of formula $Split(<title>," - ",1)
Use the plugin's Copy tag command to copy <virtual_1> to <artist>
The source code to any of my contributions is available on the same download link as the add-ons
i guess there already is an ASR preset that does this. can't check this right now.
monkey
i checked all asr presets but noone seems to run in my case !
i created a virtual tag and it seems to be ok
thanks for reply
yes. there are 2 opposite presets, which assume that artist(s) are mentioned after track title. i'll create new ASR preset for the situations like yours.
monkey
thanks for that
i have another case where artist is inside parenthesis at the end of title ?
Apocalypse Now (Wagner)
ok. no problem. i'll create one more preset.
this is one of two mentioned existing presets:
Extract artists from track title and add them to the "Artist" tag - "Title (<Custom text 1> <Artist1> <Custom text 2> <Artist2>)" format
here are updated ASR presets containing the new preset, which extracts artist from title if artist is written before the track title:
https://www.mediafire.com/file/esgu05pfhpylz8s/ASR+Presets_2024-04-27.zip/file
extract all preset to the folder "<MB folder\Plugins\ASR Presets>", open ASR, and click either "Install All" or "Install New".
Last Edit: April 27, 2024, 12:14:08 PM by boroda
monkey
thanks  :-X
i just checked it
but i can't manage to make it run
perhaps i dont understand how asr run ? it seem to be an impressive tool !!!!
is there something i do wrong ?
Last Edit: May 01, 2024, 03:14:52 PM by monkey
you selected the wrong preset. see its name and description. the preset you selected is named: TITLE (ARTIST). you need the preset for that selected track: ARTIST - TITLE
EDIT:
i see from your screenshot that you haven't installed the new preset (see download link to updated presets above). the required preset is missing in preset list.
Last Edit: May 01, 2024, 03:41:54 PM by boroda
monkey
sorry as i often say “I understand quickly, but I need a long explanation”
so i managed to use the preset and i modified it to keep the title as it
i'm not familiar with regex expressions but it's seem to be a really powerful tool
thanks for your help  :-X
