Author Topic: theatre mode  (Read 172 times)
sarashaw
am i being stupid or has theatre mode vanished  :-\
I have 3.6 8869 with an up to date theatre mode dll from the same download on win11 but i can't see it in the menus?
menu I have is under View:
Compact Menu
Start Visualiser
Visualiser >
Now Playing Menu
etc. and I'm sure it used to be in there?
thx
sarashaw
i can't delete my own message apparently!]
Anyway, i have solved it - in the settings it had become disabled - never knew that setting was there - still my confirmed stupidity may help someone else  ::)  ::)
  • Heal The World
I promise you, you're not going crazy.
I've noticed this myself maybe two or three random times in the past.
The TM plugin would be enabled but somehow not visible in the View menu.
(which is a little different to your case since you mentioned it was indeed disabled somehow).
Anyway, on each occasion, a single or double restart would usually pop it back in place, but the cause has remained a mystery.
