Author Topic: syncing my m3u playlist on mb with the Innioasis G1 android based mp3 player  (Read 2335 times)
DanielLumpkin
ive dug and dug and cant find anything that i can use in regards to syncing m3u playlist with my G1. i was able to import my entire <19k> itunes library into the MB program and ALL of it sunk fine, but i cant get a damn playlist to work. ive tried the notepad re-routing thing and i guess im to dumb or lazy to get it.
can ANYONE HELP ME im about to loose my mind messing with this shit.
  • Heal The World
You need to give more info on what the problem is exactly.
...but i cant get a damn playlist to work. ive tried the notepad re-routing thing and i guess im to dumb or lazy to get it.
What's the problem - your MP3 player cannot recognize the playlist text files generated by MusicBee?
And you know for certain that this player supports the reading of external playlists (specifically the m3u format)?
Can it create playlists itself? When you create one from it and compare it to that of MusicBee's, what's the difference between the two?
You mentioned trying to change the file paths within the playlist...so is it a matter of the player not being able to locate the tracks that the MB playlist file paths point to?
Strength and Honour (2025)
