Author Topic: space before dash  (Read 495 times)
monkey
is it possible to insert space just after the year (green) and before the dash and the same for Grouping (Blue)
i'musing virtual tag
karbock
Can you post your current virtual tag formula?
monkey
Here are
Virt Year :           {font: Segoe UI Symbol;Regular;10}{color: 0,118,59}{contrast: 100}<Year>
Virt Grouping :   {font: Segoe UI Symbol;Regular;10}{color: 176,0,0}{contrast: 100}<Grouping>
Virt Genre :         {font: Segoe UI Symbol;Regular;10}{color: 0,0,220}{contrast: 100}<Genre>
karbock
I guess that there's a bug causing MusicBee to remove the space before the centred dot when using "color" clauses,
since the album sub-header fields are displayed correctly (with space, dot, space) without "color" clauses.
Until correction of the bug, there are 2 options:
(1) Use one integrated virtual formula:
{font: Segoe UI Symbol;Regular;10}{contrast: 100}{color: 0,118,59}<Year>{color: default}" • "{color: 176,0,0}<Grouping>{color: default}" • "{color: 0,0,220}<Genre>
(2) Go on using the 3 virtual formulas, but append the following at the end of each:
" "{color: default}
In this case, the dot is not exactly centred, though.
Last Edit: March 30, 2024, 05:26:12 PM by karbock
monkey
thanks a lot ! the first one is better !!!
