Author Topic: Tags For Songs In Playlists Not Showing  (Read 234 times)
mbovice
I had some trouble moving MusicBee to a new computer and while I have  most everything setup again, the tags for every song inside a playlist are blank and it acts like the song doesn't exist. If I run a file rescan then all of the tags show in the music explorer (and also a playlist folder), but never in the playlist unless I manualy fix every tag. If I play a song within the playlist the tags get reset and I have to rescan (it also says the songs don't exist even if it's already playing). How can I get my playlists to show the tags for my songs again.
https://imgur.com/AKb3WWQ
https://imgur.com/a/kd5263g
tjinc
I can't say that I have any idea what is going on here so I'm not sure I am going to be of any help, but maybe you could give some more details that may give someone a clue on how you might proceed:
1. If you hover your mouse over the exclamation mark to the left of the (tagless) tracks, a message will pop up - what does it say?
2. Is this seen in one particular playlist or all playlists?
3. For one of these tracks, can you post images of the edit window (right click > edit), both the Tags tab (which presumably is empty) and the Properties tab.
mbovice
1. No message shows up, I can play the songs normally, but if I do locate song in library it can't find it. And on the other end if I find the song in the library and do locate in playlists it works as expected.
2. Pretty much every playlist has this issue.
3. https://imgur.com/a/xySef7f
https://imgur.com/a/9sWB17b
https://imgur.com/rdIZWZ4
