Author Topic: "Cannot access a disposed object"  (Read 450 times)
LedHarvest
Full error dump:
MusicBee v3.5.8698.34385D  (Win10.0), 18 Feb 2024 16:19:
System.ObjectDisposedException: Cannot access a disposed object.
Object name: '#=z55KGSJZeNT4Dqw4$Mg=='.
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Form.CreateHandle()
   at System.Windows.Forms.Control.get_Handle()
   at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
   at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
   at #=zx3_oPwFG2zyN8q90p4fM$TI=.#=zdBp$dWA=(Form #=zNG$Pk3A=)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=z55KGSJZeNT4Dqw4$Mg==.#=zdBp$dWA=()
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=zr0YiGKH84xdIvJDjnA==(Boolean #=zBgHGdhI=, #=ze$$JlqS7d82cEPfAAQA0zQI= #=zNWmjz70=)
   at #=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_.#=zUuT4SSXEC0LtEgnzEg==(Object #=zkMMOivE=, EventArgs #=zK60pSUM=)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
I found several other threads with this reported but no resolution - usually because the reporter didn't respond to request for further information.
This is happening to me consistently when I switch tabs then move cursor to touch left hand panel (which I have set to auto hide). It is also opening a new tab with 'Music' label each time the crash happens.
I'm running Win11 beta. All drivers etc. up to date.
Happy to provide more info as needed.
It has been reported before and i have never been able to reproduce it. Can you send a link to your settings (help/ support/ view settings)
Do you have a filter called "FLAC"? could you check it still exists in:
C:\Users\<your id>\AppData\Roaming\MusicBee\Filters\FLAC.xautopf
this should fix the problem:
Last Edit: February 20, 2024, 08:20:51 AM by Steven
LedHarvest
Hi
No FLAC filter - not even the 'Filters' folder.
However, your patched version works perfectly. Bug gone.
Nice work! :)
P.S. I forgot to mention that I had updated flac.exe, libflac.dll, and bassflac.dll to their latest versions but that clearly wasn't the cause as I'm still using them with the new patched version without problem. Any chance you could include these latest releases in the next MB release? Thanks!
herd
Same problem here, the linked patch did not solve the issue for me.
Pre patch:
2/26/2024 12:57:28 PM - 10.0.19044.0 - 3.5.8698.34385D - System.ObjectDisposedException: Cannot access a disposed object.
Object name: '#=zxdPeeS9uFa8oJzGFQK7gQYcaPZA_'.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at System.Windows.Forms.Control.Invoke(Delegate method)
   at #=zNw1gc6dmr6WcbwzSi_PPhpuKB_Qz.#=zQnBOczs=(MethodInvoker #=zXCP2iIs=)
   at #=zhPFEe1wsFkT0vvT9mUfLIzo=.#=zk4qcEJB5I_fX.#=qLtrpMTttnbRuI376oc$TW2WaNWOiJ4KDPSo_xqgh2Gs=._Lambda$__0()
Post patch:
2/26/2024 1:30:09 PM - 10.0.19044.0 - 3.5.8821.35767D - System.ObjectDisposedException: Cannot access a disposed object.
Object name: '#=zA8IN7vana6jMELu8cTSOt4qkGLJP'.
   at #=zderBTSejqOrVZdeUR2Bz4BwroFDu.#=zAZNGwIQ=(MethodInvoker #=zFmxgJGc=)
   at #=zbQrYoEEkiiVBTGQQ_GVkMK8=.#=zWbYDV0bGOWRh.#=qCE79cq5l$8tYENcRJN3FxgmpELqxOCBVeI03d4PqDq0=._Lambda$__0()
Settings file:
https://pastebin.com/2rJL0U94
That error somehow relates to the thumbnail browser. What were you doing at the time it happened?
herd
I had just finished genre tagging one artist and was navigating to a new one in the thumbnail browser.
herd
Still having this problem. Anything else I can do to help diagnose?
