Author Topic: Play to click icon in Album Cover Art  (Read 354 times)
ChriUwe
  • Heal The World
How can I change the play to click icon in album cover art in my own skin?
The above location in red is too vague for me.
I am not sure where in MusicBee that is. Can you post a screenshot?
i think the OP means this icon (click "customize panel" in "albums" view, tick "show click to play button..."):
i remember that this icon has been initially included in localization files (as a localization string entry using base64-encoded image; because it was a localized text "Play" at that time, not the icon), but MB doesn't use that localization entry anymore.
and from my screenshot (it's hiccup's "nocturne" skin) it seems that it can be overridden by bitmap skin.
  • Heal The World
Thanks boroda.
In that case, there's certainly no way to assign a custom icon to that button at the moment.
There are two hardcoded icons for it - the one on your screenshot (which appears when the slimIcons skin setting is enabled) and the other which is a solid-fill.
