Author Topic: Global Hotkey doesn't work anymore  (Read 136 times)
magia
Hi, so I've used MusicBee for about 3 years now and I set Playback: Play/Pause to the hotkey of ` and made it 'global' so I can use it even when I don't have MusicBee as the primary window. That worked perfectly until recently.
Now the hotkey is not working unless MusicBee is the main window I'm using. So if I minimize it, the hotkey stops working even though the hotkey is still 'global'. Please help!
What changed?
Did you update MB? If so, from what version to what version?
Did you update Windows?
Did you accidentally disable Global?
Even if it does still appear okay in the Preferences, setting it to something else and then back again might give it a little kick.
Also make sure no other programs have hijacked the same key for their own uses.
