I also highly recommend setting up the computer node in the navigation pane to show only filtered folder locations, and spending a little time getting used to using it. I used to use windows explorer, but after forcing myself to use the computer node to add a couple of albums that way, I will rarely use windows explorer again.
There a couple of disadvantages of using the Computer node:
- It only shows the music files, which is correct, since it is really part of the music library system. However, the standard for fan sharing of live shows is to name tracks something like "Blah290711trk01.flac" and then to use a separate "Blah290711.txt" file to give the song titles, venue, etc. Only the most recent shows have tags, so only the text file can tell you which track is which prior to doing your own tagging.
- I'm not sure if it is a bug or just a consequence of the code used, but Computer node does not obey various options set in Windows Explorer. One of those is turning off click-to-rename, and so 98% of the the album folder line responds to a click with "rename", and then none of the regular context menu items, such as "play now".
- I use a leading underline "_" to put favorite artist folder at the top of alphabetical order, but for some reason, Computer node puts "_" at the end of alphabetical sort order.
