Author Topic: VGMDB plugin crashes/closes MusicBee  (Read 1303 times)
Dweller95
It doesn't happen with every video game soundtrack I try to get art for, but I sometimes get this error and it causes MusicBee to crash or exit for some reason:
MusicBee v3.5.8447.35892D  (Win10.0), 26 Sep 2023 13:51:
   at MusicBeePlugin.Plugin.VGMdbAlbum..ctor(String url)
   at MusicBeePlugin.Plugin.loadVGMdbAlbum(Object url)
   at System.Threading.QueueUserWorkItemCallback.WaitCallback_Context(Object state)
   at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
   at System.Threading.ThreadPoolWorkQueue.Dispatch()
   at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
Obviously not a MusicBee bug.
Find the topic for the plugin that you are using and post your issue there.
Dweller95
I have, though it seems the most up-to-date version of it still contains the bug (last release was April 2022).
I have..
In that case it will be up to the creator of that plugin to respond to your report there.
