Is there anyplace that you can see how others have arranged their panels and is there a way to find out how to make these different panels. I want to make the left panel have playlists on the top and below show the contents of the playlist chosen. Hope this makes sense.
It's really not difficult to achieve this, but I guess the coin has to drop first on how setting up and placing panels is done in MusicBee.
In the 'arrange panels' configuration panel, all you need to do is to find the ' playlist directory' and the 'playing tracks' elements.
Simply drag and drop them to a location in e.g. the 'left sidebar' or in the 'left main panel', and that's pretty much it.
If you are afraid to experiment and possibly mess-up thing, use a separate portable install of MusicBee for learning how to do this.
