Author Topic: Double clicking song track to play always enters rename title state  (Read 377 times)
slappy
Hi, I have not found a way to disable changing the song title name when double clicking and this is a real nuisance. Not really interested in changing mouse settings etc as I do not have this issue elsewhere. Thanks you if you can help me, no worries if not.
That only happens when you double-click (too) slowly.
A fast double-click will play the track.
You can also disable the feature completely.
See the topmost option in the Preferences > Tags (2) panel.
slappy
That fixed it immediately, yeah I'm pretty incompetant I guess. Thanks a lot, I appreciate it
there does seem to be some sort of flaw with this so i will have a closer look and see if something needs changing
What would be the flaw here?
I believe it's intentional behaviour, and I have been making use of the fact that you can either fast- or slow double-click to perform either editing or playing.
i was wrong - it is working as intended but i might change it to add some extra time padding as i have seen this complaint a number of times
chin
and how would you select a track?
The single click could both select and then play the track. Why do you need to select if it wont play?
Read and digest the replies and search the forum and the web chin.
And, you are polluting somebody else's topic, in which the original question already has been answered and was solved.
Bad chin!
Again…
Last Edit: May 25, 2023, 07:14:05 PM by hiccup
MotleyG
Umm, when listening to a playing track while making edits to others?
is there an option to play with a single click?
You are hijacking (polluting) a thread with an unrelated question. Create a new thread for questions that are off-topic.
Your continued misbehaving by not following common forum etiquette (not searching, false bug reports, hijacking threads, etc.) is going to get you banned from the forum. Depending on what the next infraction is (or are) will determine if the ban is temporary or permanent.
