Author Topic: Add VST3/64-bit VST support  (Read 1047 times)
nojwe
Add support for VST3/64-bit plugins
+ 1
FWIW, this doesn't require a 64-bit player, just a 64/32-bit compatible VST host/bridge. Foobar finally came out with one of its own for either the 32 or 64-bit versions of its player, and VST3/VST2 64-bit plugins work fine in either.  Probably was a "bear" to code though!
